JTAG Programming of XC5204 Xilinx FPGA
Assem
Newbie level 1
xilinx xc5204 board
I have Tried to program the XC5204 FPGA using the Xilinx Paralell Cable IV and the JTAG programmer of Alliance 3.1. The JTAG programmer finshes proramming in just 4 seconds and gives a message the programming has finished successfully, yet the FPGA is not programmed DONE does not go HIGH. Can anyone help me solve this problem?
A
andonie12
Assem,
I think the way you hooked the "Done" signal on the Schematic Board is incorrect.
Make sure the "Done" signal is connected to the FPGA, Prom and a pullup resistor.
Don't worry about the "Done" signal for now. Check if your FPGA is working after you downloading the program:
Check the following:
1) Make sure your vcc and vcco is correctly connected to the FPGA.
2) Make sure your input clock is there
3) Check out if there is any output signals
