A JFET operates by shutting off an already formed channel between source and drain in the transistor, unlike a MOSFET where the gate voltage creates a channel between source and drain.
I think you mean vds less than vgs-vp. The drain to source in a JFET without a gate applied is like a resistor. The gate is, for instance in a n type JFET, a p diffusion. A reverse bias on the p-type gate to the n-type channel creates a depletion region along the junction. With enough voltage, the depletion region can grow and totally pinch off the channel from source to drain.
