Issues with sync FIFO Implementation in SystemVerilog – Incorrect Data Read & Flag Behavior
naajap
Newbie
Newbie level 1
I'm working on a 4-depth, 8-bit wide FIFO in SystemVerilog. I’ve written both the FIFO module and the testbench, but I’m encountering unexpected behavior in data read operations and flag updates.
module fifo #(
    parameter DEPTH = 4,  // Depth of the FIFO
    parameter WIDTH = 8   // Width of each entry
    input logic clk,
    input logic rst,
    input logic [WIDTH-1:0] data_in,
    input logic wr_en,
    input logic rd_en,
    output logic [WIDTH-1:0] data_out,
    output logic full,
    output logic empty
    logic [WIDTH-1:0] mem [0 : DEPTH-1]; // FIFO memory
    logic [1:0] wr_ptr;  // Write pointer (2-bit for DEPTH=4)
    logic [1:0] rd_ptr;  // Read pointer (2-bit for DEPTH=4)
    logic [2:0] count;   // Counter to track elements (needs 3 bits for DEPTH=4)
    always_ff @(posedge clk or posedge rst) begin
        if (rst) begin
            wr_ptr <= 0;
            rd_ptr <= 0;
            count <= 0;
            full <= 0;
            empty <= 1;
        end else begin
            // Handle simultaneous read and write
            if (wr_en && !full && rd_en && !empty) begin
                mem[wr_ptr] <= data_in; // Write new data
                wr_ptr <= (wr_ptr + 1) % DEPTH;
                rd_ptr <= (rd_ptr + 1) % DEPTH; // Read from FIFO
            end
            // Only write
            else if (wr_en && !full) begin
                count <= count + 1;
            end
            // Only read
            else if (rd_en && !empty) begin
                data_out <= mem[rd_ptr];
                count <= count - 1;
            end
            // Correctly update full and empty flags
            full <= (count == DEPTH - 1);
            empty <= (count == 0);
        end
    end
endmodule
module test_fifo;
    // Declare signals
    logic clk;
    logic rst;
    logic [7:0] data_in;
    logic wr_en;
    logic rd_en;
    logic [7:0] data_out;
    logic full;
    logic empty;
    // Instantiate FIFO DUT
    fifo #(4, 8) dut (
        .clk(clk),
        .rst(rst),
        .data_in(data_in),
        .data_out(data_out),
        .wr_en(wr_en),
        .rd_en(rd_en),
        .full(full),
        .empty(empty)
    // Clock generation
    initial begin
        clk = 0;
        forever #5 clk = ~clk;
    end
    // Reset generation
    initial begin
        rst = 1;
        #20 rst = 0;
    end
    // Test sequence
    initial begin
        // Initialize signals
        data_in = 0;
        wr_en = 0;
        rd_en = 0;
        // Wait for reset to complete
        @(negedge rst);
        // Test 1: Write data to FIFO
        $display("Test 1: Writing data to FIFO");
        for (int i = 0; i < 4; i++) begin
            @(posedge clk);
            data_in = i;
            wr_en = 1;
            rd_en = 0;
            $display("Write Data: %h, Full: %b, Empty: %b", data_in, full, empty);
        end
        @(posedge clk);
        wr_en = 0;
        // Test 2: Read data from FIFO
        $display("Test 2: Reading data from FIFO");
            @(posedge clk);
            wr_en = 0;
            rd_en = 1;
            $display("Read Data: %h, Full: %b, Empty: %b", data_out, full, empty);
        end
        @(posedge clk);
        rd_en = 0;
        // Test 3: Simultaneous read and write
        $display("Test 3: Simultaneous read and write");
            @(posedge clk);
            data_in = i + 4;
            wr_en = 1;
            rd_en = 1;
            $display("Write Data: %h, Read Data: %h, Full: %b, Empty: %b", data_in, data_out, full, empty);
        end
        @(posedge clk);
        wr_en = 0;
        rd_en = 0;
        // Test 4: Test FIFO full condition
        $display("Test 4: Testing FIFO full condition");
        for (int i = 0; i < 5; i++) begin
            @(posedge clk);
            data_in = i + 8;
            wr_en = 1;
            rd_en = 0;
        end
        @(posedge clk);
        wr_en = 0;
        // Test 5: Test FIFO empty condition
        $display("Test 5: Testing FIFO empty condition");
            @(posedge clk);
            wr_en = 0;
            rd_en = 1;
        end
        @(posedge clk);
        rd_en = 0;
        // End simulation
        $display("Simulation completed.");
        $finish;
    end
  endmodule
Write Data: 00, Full: 0, Empty: 1
Write Data: 01, Full: 0, Empty: 1
Write Data: 02, Full: 0, Empty: 0
Write Data: 03, Full: 0, Empty: 0
Read Data: xx, Full: 0, Empty: 0
Read Data: 00, Full: 0, Empty: 0
Read Data: 01, Full: 1, Empty: 0
Read Data: 02, Full: 0, Empty: 0
Write Data: 04, Read Data: 03, Full: 0, Empty: 1
Write Data: 05, Read Data: 03, Full: 0, Empty: 1
Write Data: 06, Read Data: 03, Full: 0, Empty: 0
Write Data: 07, Read Data: 03, Full: 0, Empty: 0
Write Data: 08, Full: 0, Empty: 0
Write Data: 09, Full: 0, Empty: 0
Write Data: 0a, Full: 1, Empty: 0
Write Data: 0b, Full: 0, Empty: 0
Write Data: 0c, Full: 0, Empty: 0
Read Data: 0b, Full: 0, Empty: 0
Read Data: 0c, Full: 0, Empty: 0
Read Data: 08, Full: 0, Empty: 0
Read Data: 09, Full: 1, Empty: 0
  1. In my testbench, the first read operation outputs xx, even though data should have been correctly written into the FIFO.
  2. When performing simultaneous read and write operations, I observe unexpected outputs in the Read Data
  3. In Test 4 (FIFO full condition), full is sometimes not asserted when the FIFO is full, and in Test 5, empty remains 0 even when all elements are read.
    Request for Help: How can I ensure that the first read correctly outputs the first written value (00 instead of xx)? Why is the read pointer (rd_ptr) seemingly stuck at 03 during simultaneous read/write? How can I ensure full/empty flags update properly, especially during simultaneous operations?
    Any insights or suggestions would be greatly appreciated. Thanks in advance!
Just take a quick look at your RTL code. There's some bugs.
1): doesn't update data_out at this condiction:
2): empty, full flag will be 2T delay of FIFO read/write operation.
You can choose to use another always block to generate full/empty flag using combination logic.
3): If you want to describe data_out at the same always block, you'd better also give reset value to data_dout (make sure your code is synthesiable).
PS: you'd better have deeper understanding of digital circuit before using verilog/sv to coding it.
Digital IC/FPGA Design Part 1: CMOS Gates and Arithmetic Datapath: https://www.udemy.com/course/digita...c-datapath/?referralCode=005DA1FEF9D390C0CCB7
Digital IC/FPGA Design P3: Common Used Hardware Architectures: https://www.udemy.com/course/digita...hitectures/?referralCode=365C67358DCDD5237CCD
LaTeX Commands Quick-Menu:
