akshayakumar
Newbie
Hi everyone,
I'm using the MAX17502H step-down DC-DC converter to convert 5 V input to a 3.3 V output. Based on the design calculations, the required inductor value came out to be approximately 24.75 μH. However, due to component availability, I used a 22 μH inductor instead.
The issue I'm facing is that the output voltage is not regulating when the input is exactly 5 V. The converter only starts generating the expected 3.3 V output when the input voltage is increased above approximately 5.3 V.
I’m trying to understand whether this behaviour is due to the lower inductor value, the dropout voltage of the converter, or something else. According to the datasheet, the device should support 5 V to 3.3 V conversion, so I’m unsure why it's failing at 5 V input.
Has anyone experienced similar behaviour or can suggest what might be causing this? Any help would be appreciated!
please find attached schematic below
Thanks in advance!
Thanks in advance!
