issue with generated clocks in encounter
shelkerahul
Member level 4
Bangalore
Hi All,
I am trying clock tree synthesis in first encounter. My design has few generated clocks. I have created clock tree specification file, but my generated clocks are missing in clock tree specification file. Now the problem is how to build clock tree for generated clocks
Thanks
Rahul
Hi ,
You have to update your CTS config file including clk generation points .
or Add create clk on generate clk points with specific source clk latency .
Thanks & Regards
yln
Hi yln2k2,
Thanks for reply, but this is last option to edit clock specification file to add these generated clock manually. Is there any option that when i say "generate clock spec file" tool should generate it automatically?
Thank you
