Issue in two integer array comparison
ecaits
Member level 4
Member level 4
Dear Sir,
I have stored setpoint value in EEPROM memory in by keypad and I want to compare setpoint value with process value. Process value is stored in one array, say data[5]. I read the setpoint value from EEPROM and again stored in another array, say presetvalue[5]. I am using below logic to compare the both value but it is not working properly. I have used RC0 pin, which is connected to LED. When PV is higher than SV then RC0 pin will be high so LED should be glow.
for(i=0;i<5;i++)// To read the setvalue from
EEPROM
value=eeprom_read(i);
presetvalue=value; // Stored setvalue in
} presetvalue[5] array
for(i=0;i<5;i++) // Comparison logic for setvalue
and process value
if(data > presetvalue) // When PV>SV,
RC0 pin high
RC0=1;
i=5;
else if(data==presetvalue) // If equal then compare next bit (From MSB to LSB)
{ RC0=1; }
else if(data < presetvalue) // When
PV<SV, RC0 pin low
RC0=0;
i=5;
Plz suggest me where may be problem.
If there is another good logic, then plz suggest me.
Thanks in advance,
you are comparing each element of the array and setting RCO
consider comparing array with elements 1,2,3,4,5 with array 1,4,2,6,1
1. first elements are the same 1=1 RC0=0
2. second 2 < 4 RC0 = 1
3. third 3 > 2 RC0=0
4. fourth 4 < 6 RC0=1
5. fifth 5>1 RCO=0
RC0 is set 0 or 1 depending on corresponding elements of the array
is this what you want to do? if not what?
could you give us some examples of your data and explain what results you would expect?
You want to store a flag in eeprom and read it on restart or do you want to store 5 bytes in eeprom and read it on restart? Is it a password you are storing or some limit value like temperature? What you want to store in eeprom, signed / unsigned 8 bit or 16 bit, signed / unsigned 8 / 16 bit, etc...
You want to compare value already stored in eeprom with what value after restart? From where do you get the data which you compare with data in eeprom?
