ISR termination for LPC2148 (Interrupts)
shruv
Member level 2
Member level 2
How to exit from an ISR written for lpc2148? The ISR is not terminating and coming back to the main function.
State the specific compiler in use and post your code, using either CODE or SYNTAX tags, so that it can be examined and proper advice can be offered.
However, one of the common issues is the interrupt flag which is triggering the interrupt is not cleared and acknowledge ISR completion before exiting the ISR.
The following tutorial should offer some guidance if using the KEIL compiler:
LPC2148 Interrupt Tutorial
BigDog
Reactions: shruv
    shruv
