Register Log in
ISPpgm do not found device
lhbzx1984
Newbie level 1
china
ISPpgm do not found device that diplay "device signature do not match" when I download hex file by 89s52
I need help ! thanks, hardware or software has problem?
santoshaxl
Advanced Member level 2
some where left alone
if your computer is infected with viruses it may happen,tell me one thing which isp programmer you are using ?
keanhong2
Newbie level 6
i think u are using asim khan ISP programming 3.0a
your LPT port connection pin 2 connect to pin 12 will solve this problem , 2 to 12 is to let ISP program verify which type of MCU are programing . i tested it working without any msg .
santoshaxl
if you are using asim khan programmer then check this pic if ur (fuse bytes) command button is highlighted or not if that is not highlighted then your system is infected with viruses scan for viruses .
Added after 2 minutes:
check for fuse bytes command button
qwertyuiop415263
Full Member level 4
Pakistan
you should check whether the mcu is 89s52 or not,, bcz 89C52 is not programmed using asim's khan prog. or you should check your cable. or your burner may have problem.
Toggle Sidebar
