Isolating LVDS signals
Los Frijoles
Full Member level 1
Provo, Utah, United States
Lately I have been designing a device which requires an isolated high speed data link. I came across LVDS as how many high speed serial links are accomplished. However, I need to isolate it electrically from the receiving end and so I was wondering how that could be done.
I had an idea that one could use a 1:1 ratio balun like so since they are transformers essentially designed for higher frequencies, but I am not sure this gives enough isolation (I am going for a minimum of 500V isolation):
+LVDS----    --------
-LVDS----    --------
LVDS      Balun   Receiver side
side            with terminating resistor (not shown)
I also thought of using conventional optoisolators or galvanic isolators, but isolators at the speeds I would like (100mbps or greater) either don't exist or are expensive (this is a hobby project with the goal being to keep costs down).
Any thoughts?
If you have a balanced high density data stream (like 8b/10b
continuous mode) this ought to be OK. In burst mode you'd
end up operating the receiver with shorted input, which some
receivers' failsafe modes will make a known output and some,
unknown.
The outputs will throw 4mA whether it's a winding or a resistive
load.
There are however digital isolation products that exist specifically
for this purpose. Check TI's new stuff in this line.
