There's are EMC and other regulations restricting the magnetic far field emitted by devices operating in 100 kHz range. I would expect that e.g. Qi chargers have no problems to keep the present regulations. A wireless car charger operating at a kW power level could be a different thing.
As already explained, due the small size of the inductive couplers relative to the wavelength, only a very small amount of power is radiated as electromagnetic wave. If you try DXing (reception of distant radio stations) in the long wave band, you'll nevertheless become aware of inductive chargers in the vicinity. It's forseeable that the proliferation of inductive chargers will contribute to the ever-present "electro smog", in so far some pompous plans like the said kW chargers should be probably better not implemented, respectively the existing EMC regulations not relaxed for their promotion.
