MrBit
Member level 1
Hi all.
I've got an issue I have been dealing with for some time time and still can't find the root cause.
My application uses a MCU DAC to control the buck converter +V_AMP output voltage (range covered is about 10V to 35V) in order to feed a dynamic load.
Load changes do not cause issues.
Enabling the output (at any given output voltage and load status) by using EN control input does not cause issues.
Disabling the output (at any given output voltage and load status) by using EN control input does not cause issues.
Raising the buck converter output voltage (while enabled) does not cause issues.
Lowering the buck converter output voltage 10V or more (while enabled) blows U9 and R25 up.
Applying a voltage ramp down in firmware to progressively lower the output voltage mitigates the problem, but a potential firmware malfunction still compromises the integrity of the hardware.
Also, this makes the circuit too slow, which represents an issue.
Simulations do not show anything.
After buck converter and resistor have been damaged, pins PHASE, BOOT, VCC5V and VIN show low resistance to ground.
Please see attached schematic for reference.
Any comments/ideas would be appreciated.
Thanks
Thanks
