king_yiping
Newbie level 2
A: the behavioral simulation result is right !
B:when comes to synthesize process
ISE 11 gives error information:
ERROR:Xst:1706 - Unit <synapse>: port <i<31>> of logic node <_old_i_7<31>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<30>> of logic node <_old_i_7<30>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<29>> of logic node <_old_i_7<29>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<28>> of logic node <_old_i_7<28>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<27>> of logic node <_old_i_7<27>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<26>> of logic node <_old_i_7<26>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<25>> of logic node <_old_i_7<25>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<24>> of logic node <_old_i_7<24>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<23>> of logic node <_old_i_7<23>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<22>> of logic node <_old_i_7<22>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<21>> of logic node <_old_i_7<21>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<20>> of logic node <_old_i_7<20>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<19>> of logic node <_old_i_7<19>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<18>> of logic node <_old_i_7<18>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<17>> of logic node <_old_i_7<17>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<16>> of logic node <_old_i_7<16>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<15>> of logic node <_old_i_7<15>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<14>> of logic node <_old_i_7<14>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<13>> of logic node <_old_i_7<13>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<12>> of logic node <_old_i_7<12>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<11>> of logic node <_old_i_7<11>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<10>> of logic node <_old_i_7<10>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<9>> of logic node <_old_i_7<9>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<8>> of logic node <_old_i_7<8>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<7>> of logic node <_old_i_7<7>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<6>> of logic node <_old_i_7<6>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<5>> of logic node <_old_i_7<5>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<4>> of logic node <_old_i_7<4>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<3>> of logic node <_old_i_7<3>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<2>> of logic node <_old_i_7<2>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<1>> of logic node <_old_i_7<1>> has no source
ERROR:Xst:1706 - Unit <synapse>: port <i<0>> of logic node <_old_i_7<0>> has no source
ERROR:Xst:1847 - Design checking failed
---------- Post added at 04:50 ---------- Previous post was at 04:45 ----------
C Source Code:
module synapse(sys_clk,neuron_clk,reset,synapse_add,pre_s pikes,calculate_ready,synapse_output);
parameter prenn=3;
parameter neuron_number=4;
input sys_clk,neuron_clk,reset;
input[15:0] synapse_add;
input[prenn-1:0] pre_spikes;
output calculate_ready;
output[15:0] synapse_output;
reg reg_neuron_clk,neuron_clk_rise;
reg start_calculate,calculate_ready;
reg[15:0] synapse_outputs[neuron_number-1:0];
wire[7:0] rand;
integer i,j;
---------- Post added at 04:54 ---------- Previous post was at 04:50 ----------
always(posedge sys_clk) //plz add char "at" here
begin
if(reset)
begin
calculate_ready<=0;
start_calculate<=0;
i=0;
j=0;
end
else
begin
reg_neuron_clk<=neuron_clk;
neuron_clk_rise<=neuron_clk&(~reg_neuron_clk);
if(neuron_clk_rise)
begin
calculate_ready<=0;
start_calculate<=1;
for(i=0;i<neuron_number;i=i+1)
begin
synapse_outputs<=0;
end
i=0;
end
if(start_calculate)
begin
if(i<prenn&&pre_spikes)
begin
for(j=0;j<neuron_number;j=j+1)
begin
synapse_outputs[j]<=synapse_outputs[j]+rand;
end
i=i+1;
end
else
begin
i=i+1;
end
if(i==prenn)
begin
i=0;
j=0;
start_calculate<=0;
calculate_ready<=1;
end
else
begin
calculate_ready<=0;
end
end
end
end
random_number inst_rand_number(.sys_clk(sys_clk),.reset(reset),. rand(rand));
assign synapse_output=(calculate_ready==1)?synapse_output s[synapse_add]:0;
endmodule
D: I followed the instructions given below, but it doesn't work
ERROR:Xst:1706 - Unit <MIPS>: port <step_pulse> of logic node <_n0000> has no source
To get around this error, you will have to change the XST FSM (Finite State Machine) options. Do this, right-click on “Synthesis-XST” in the center left panel in Project Navigator. Select “Properties”. Once in the “Process Properties” menu, select the “HDL Options” tab. Then, click on the drop-menu of “FSM Encoding Algorithm”. Change the value from “Auto” to “None”. For some reason, XST is too smart in “Auto” mode and optimizes out the logic that drives the step_pulse signal.
E:
if(i==prenn)
begin
i=0;
j=0;
start_calculate<=0;
calculate_ready<=1; // when changed into calculate_ready<=0, It works OK, very STRANGE!!!
end
else
begin
calculate_ready<=0;
end
---------- Post added at 04:55 ---------- Previous post was at 04:54 ----------
Any suggestions or help will be appreciated!!
C Source Code:
parameter prenn=3;
wire[7:0] rand;
integer i,j;
begin
if(reset)
begin
calculate_ready<=0;
start_calculate<=0;
i=0;
j=0;
end
else
begin
if(neuron_clk_rise)
begin
calculate_ready<=0;
start_calculate<=1;
begin
synapse_outputs<=0;
end
i=0;
end
if(start_calculate)
begin
begin
begin
end
i=i+1;
end
else
begin
i=i+1;
end
if(i==prenn)
begin
i=0;
j=0;
start_calculate<=0;
calculate_ready<=1;
end
else
begin
calculate_ready<=0;
end
end
end
end
endmodule
E:
if(i==prenn)
begin
i=0;
j=0;
start_calculate<=0;
end
else
begin
calculate_ready<=0;
end
