wd5gnr
Newbie level 6
ISE 10.1 Error
I've been using ISE 10.1 for awhile. The other day my system crashed and corrupted my project. So I made a new project and copied all the .v, .xco, .ucf files etc. When I go to set the Design Strategy (which used to work) I get an error message saying that PAR Overall Effort property can't be found. In addition, that setting in the dialog is grayed out (even on the Balanced/unlock) setting.
So I've tried deleting everything in my home directories for Xilinx, renaming /opt/Xilinx and reinstalling from my CD (this is Linux). But still this error persists. Worse still, I'm not making timing anymore since this has happened :-(
I did try putting -ol high on the "other options" part but I can't tell if that's working.
Any ideas?
Update: Ok, so if extra effort is set, that overrides the "overall effort" but that still doesn't explain the error message which I never used to get.
Any ideas?
