A contract Engineering company have designed us some 15W xenon flash tube lamps.
I have noticed that there are several 250V capacitors providing the 210uF of capacitance used to flow current through the xenon tube when its struck….however, one 22uF , 250V capacitor is connected to the others via a diode , such that it cannot actually discharge via the xenon tube…..thus when the xenon tube strikes, this particular 22uF capacitor stays charged up.
….this particular 22uF capacitor is used to provide the voltage to the primary of the trigger transformer.
But why, I ask, have they bothered to do this?, …because our 5W xenon flash lamp does not bother to have a separate capcitor like this for provision of tube trigger transformer primary voltage.
…..so I believe that they must have been having trouble triggering the tube, and so are triggering it multiple times, and due to the multiple triggering, they need this extra capacitor to provide adequate trigger voltage to the primary of the trigger transformer as the tube flows current and discharges the 250V capacitors.
Anyway, I am asking myself why on earth they would need to trigger the tube multiple times?
…….well, i believe that the answer lies in the stray inductance in the connections linking up to the xenon tube……….that is, when the xenon tube suddenly starts flowing current, this suddenly rising current flows in the stray inductance of the wires, and temporarily (for just 1.5us) reduces the tube voltage to near 0V.
……on falling to 0V, the tube goes out, and then needs retriggering to make it strike properly.
The following schematic and waveform indicate the problem………in the waveform you can see how the tube voltage suddenly falls to near zero as the tube starts conducting…..
Schematic (xenon tube represented with current source):
https://i45.tinypic.com/ops8kg.jpg
Waveform showing tube voltage.
https://i48.tinypic.com/2vsnf4h.jpg
We are triggering the tube with Capacitive external triggering as on page 4 of the following…..
Anyway, do you believe my diagnosis is correct…..ie that it’s the stray inductance that’s making them need to multiple trigger.?
Also, do you know a better solution to this problem than multiple triggering?
