T
treez
Supposing we were desperate for a 2 phase mains supply in UK.
We can’t wait to order one, and can’t afford one.
We then find that 2 mains wall sockets 3 metres apart in our (commercial) office actually are from two different phases…….they share the same neutral and obviously the same earth.
Now, we have a 15kW power supply (VDC output = 50 to 800VDC and Iout = 0 to 30A).
This power supply can take a 2 phase mains input.
What might be the problems of connecting up this somewhat “contrived” 2 phase input to this power supply?
Would you suppose that the sheer area of the noise current loop bounded by the 2 phase wires (from the two different mains wall sockets) would be so big that the noise would stop the power supply from working?
(We were thinking that we can add a common mode filter comprising a common mode choke to which the two phases would be connected. Also, we can add Y caps to Earth from each phase. Also, we can add diff mode caps between the 2 phases.)
