Jasper Chow
Junior Member level 3
USB topology is a star-like pyramid. In my veiw, it has nothing to do with bus. Is it misnamed? Or for some other reason?
Note: This feature currently requires accessing the site using the built-in Safari browser.
I assume you are referring to 1000BASE-T ethernet standard, which is mostly used for wired 1 GBPS links.why does usb transmit data via baseband digital signal, while ethernet has to carry data on modulated analogous signal?
