Is this serial data transfer appropriate for encryption?
ganavel9783
p16_tprp
hi every1,
i wrote a pc application in Visual C which could send text file by block of 8 bytes.i short pin 2 and 3 of the serial port to test the GUI without any hardware.i was able to get back data by block of 8 bytes.any incomplete block is padded with a space character.
Later i tested the GUI with PIC16f877.I loaded the following code from microchip's application note AN774 to test serial comm using buffres:
P16_TWRP.ASM Poll to receive, Wait to transmit, No buffers, Eight bit data
the code for the .asm file is show below:
; Filename: p16_tprp.asm
; Author:  Mike Garbutt
; Company: Microchip Technology Inc.
; Revision: 1.00
; Date:  August 6, 2002
; Assembled using MPASMWIN V3.20
; Include Files: p16f877.inc V1.12
; PIC16XXX USART example code with transmit and receive polling. The
; main routine calls calls subroutines to poll for received data and for
; data to be transmitted. Received data is put into a buffer, called
; RxBuffer. When a carriage return <CR> is received, the received data
; in RxBuffer is copied into another buffer, TxBuffer. The data in
; TxBuffer is then transmitted by the transmit polling routine.
 list p=16f877  ;list directive to define processor
 #include <p16f877.inc> ;processor specific definitions
 errorlevel -302  ;suppress "not in bank 0" message
 __CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _HS_OSC & _WRT_ENABLE_OFF & _LVP_OFF & _DEBUG_OFF & _CPD_OFF
;Constants
SPBRG_VAL EQU .103  ;set baud rate 9600 for 16Mhz clock
RX_BUF_LEN EQU .8  ;length of receive buffer
TX_BUF_LEN EQU RX_BUF_LEN ;length of transmit buffer
;Bit Definitions
ReceivedCR EQU 0  ;bit indicates <CR> character received
;Variables
 CBLOCK 0x020
 Flags   ;byte to store indicator flags
 RxByteCount  ;number of bytes received
 TxByteCount  ;number of bytes to transmit
 TxPointer  ;pointer to data in buffer
 ENDC
 CBLOCK 0x0A0
 TxBuffer:TX_BUF_LEN ;buffer for data to transmit
 ENDC
 CBLOCK 0x120
 RxBuffer:RX_BUF_LEN ;buffer for data received
 ENDC
;Macros to select the register bank
;Many bank changes can be optimized when only one STATUS bit changes
Bank0  MACRO   ;macro to select data RAM bank 0
 bcf STATUS,RP0
 bcf STATUS,RP1
 ENDM
Bank1  MACRO   ;macro to select data RAM bank 1
 bsf STATUS,RP0
 bcf STATUS,RP1
 ENDM
Bank2  MACRO   ;macro to select data RAM bank 2
 bcf STATUS,RP0
 bsf STATUS,RP1
 ENDM
Bank3  MACRO   ;macro to select data RAM bank 3
 bsf STATUS,RP0
 bsf STATUS,RP1
 ENDM
;This code executes when a reset occurs.
 ORG     0x0000  ;place code at reset vector
ResetCode: clrf    PCLATH  ;select program memory page 0
  goto    Main  ;go to beginning of program
;This code executes when an interrupt occurs.
 ORG 0x0004  ;place code at interrupt vector
InterruptCode: ;do interrupts here
 retfie   ;return from interrupt
;Main routine calls the transmit and receive polling routines and checks for a
;carriage return. It then calls a routine to copy the data to transmit back.
Main:  call SetupSerial ;set up serial port and buffers
 ;do other initialization here
MainLoop: call TransmitSerial ;go transmit data if possible
 call ReceiveSerial ;go get received data if possible
 btfsc Flags,ReceivedCR ;check if <CR> received
 call CopyRxToTx ;if so then go copy the data
 ;do other stuff here
 goto MainLoop ;go do main loop again
;Check if data received and if so, place in a buffer. Also check for <CR>.
ReceiveSerial: Bank0   ;select bank 0
 btfss PIR1,RCIF ;check if data
 return   ;return if no data
 btfsc RCSTA,OERR ;if overrun error occurred
 goto ErrSerialOverr ; then go handle error
 btfsc RCSTA,FERR ;if framing error occurred
 goto ErrSerialFrame ; then go handle error
 movlw RX_BUF_LEN ;get buffer length
 xorwf RxByteCount,W ;and compare with byte count
 btfsc STATUS,Z ;check if buffer is full
 goto ErrRxBufOver ; go handle it if full
ReceiveSer1:
 BANKISEL RxBuffer ;bank bit for indirect addressing
 movlw LOW RxBuffer  ;get start address of buffer
 addwf RxByteCount,W ;add current byte number
 movwf FSR  ;and place in FSR pointer
 movf RCREG,W  ;get received data
 movwf INDF  ;and place in buffer
 xorlw 0x0d  ;compare with <CR>
 btfsc STATUS,Z ;check if the same
 bsf Flags,ReceivedCR ;indicate <CR> character received
 incf RxByteCount,F ;increment count of bytes received
 return
;error because OERR overrun error bit is set
;can do special error handling here - this code simply clears and continues
ErrSerialOverr: bcf RCSTA,CREN ;reset the receiver logic
 bsf RCSTA,CREN ;enable reception again
 return
;error because FERR framing error bit is set
ErrSerialFrame: movf RCREG,W  ;discard received data that has error
 return
;error because Rx buffer is full and new data has been received
;can do special error handling here - this code simply overwrites last data
ErrRxBufOver: decf RxByteCount,F ;decrement byte count to overwrite last
 goto ReceiveSer1
;Transmit data if there is data in the transmit buffer.
TransmitSerial: Bank0   ;select bank 0
 movf TxByteCount,F ;check if data to be transmitted
 btfsc STATUS,Z
 return   ;return if no data to be transmitted
 btfss PIR1,TXIF ;check if transmitter busy
 return   ;return if transmitter busy
 BANKISEL TxBuffer ;bank bit for indirect addressing
 movf TxPointer,W ;put pointer into WREG
 movwf FSR  ;and then into FSR
 movf INDF,W  ;get the data to be transmitted
 movwf TXREG  ;and transmit
 decf TxByteCount,F ;decrement number of bytes left
 incf TxPointer,F ;increment pointer to next data
 return
;Set up serial port and buffers.
SetupSerial: Bank1   ;select bank 1
 movlw 0xc0  ;set tris bits for TX and RX
 iorwf TRISC,F
 movlw SPBRG_VAL ;set baud rate
 movwf SPBRG
 movlw 0x24  ;enable transmission and high baud rate
 movwf TXSTA
 movlw 0x90  ;enable serial port and reception
 movwf RCSTA
 clrf TxByteCount ;clear transmit buffer data count
 clrf RxByteCount ;clear receive buffer data count
 clrf Flags  ;clear all flags
 return
;Copy data from receive buffer to transmit buffer to echo the line back
CopyRxToTx: Bank0   ;select bank 0
 movf TxByteCount,F ;check if still transmitting data
 btfss STATUS,Z
 goto ErrTxBufOver ;go handle error if still busy
CopyRxTx1:
 addwf TxByteCount,W ;add current byte number
 movf INDF,W  ;get data from Rx buffer
 movwf TxPointer ;and save for later (reusing register)
 movlw LOW TxBuffer  ;get start address of buffer
 movf TxPointer,W ;get saved data (not a pointer)
 movwf INDF  ;and place in Tx buffer
 incf TxByteCount,F ;increment count of bytes in TxBuffer
 decfsz RxByteCount,F ;decrement counter and see if all done
 goto CopyRxTx1 ;repeat if not done
 movlw LOW TxBuffer ;take address of transmit buffer
 movwf TxPointer ;and place in transmit pointer
 bcf Flags,ReceivedCR ;clear indicator for <CR> received
 return
;error because still transmitting data and new data is available to transmit
;can do special error handling here - this code simply discards the new data
ErrTxBufOver: clrf RxByteCount ;reset received byte count
 return
 END
i've managed to include a carriage return <cr> character after each block of 8 bytes in my PC application.i also set the buffer length at 8 bytes in the p16_tprp.asm for my PIC16f877 code.i tested the serial comm with text files which has 7,8,9,15,16 and 17 characters.
however,when i tested the code with 8 bytes as buffer length on da PIC side, i realise that the 8th bytes for the text file was replaced by the <cr> character.then when i changed the buffer length from 9 onwards on da PIC side, the data reception was working fine.
after that i edited my PC application code so that the <cr> character is send after 2 blocks of 8 bytes.this time i set the buffer length to 16, and when a text file more than 15 bytes is sent, the 16th byte is replaced by the <cr> character.then when i change the buffer length from 17 onwards on da PIC side, the data reception was working fine.
so my question is this data transfer appropriate for me to proceed with encrypting text files using the AES algoithm since the algorithm works with blocks of 16 bytes for encryption??
regards,
ganavel9783
16f877a fsr
Hi you can go ahead with encryption at application level. i.e. use some block cipher and encrypt at application level itself.
use AED, DES, 3DES like encryption algorithms
low rxbuffer
So you send 9 bytes (8 + <cr>).
Now look at this statement in your code :
ErrRxBufOver: decf RxByteCount,F ;decrement byte count to overwrite last received
              goto ReceiveSer1
Because you use a linear buffer of 8 bytes rather than a circular one, before receiving <CR>, PIC16F877 will keep the pointer to the last 8th byte in the receiving buffer regardless the number of received bytes.
Obvious until a <CR> will appear. And funny, <CR> is the 8th byte stored in the RxBuffer, which will then be coppied to TxBuffer.
This way for a RxBuffer of 8 bytes and a string "ABCDEFGHIJKLMNO<CR>" sent by PC, you'll get back "ABCDEFG<CR>" and "HIJKLMNO" lost.
If you set the PIC16F877 receiving buffer length to 17 and take care not to overwrite it by sending subsequent 16 bytes (not until you get back the previous 16) then you can go ahead with encryption.
Do you want to build up a dongle or trying to mask your updated code loaded by PIC16F877 bootloader ?
