Is this code correct?
Advanced Member level 6
Bangalore, India
Is this code correct? I am using PWM of 38 KHz to generate IR bursts and sending some data. I am attaching mikroC Project files + Proteus file + DSO output. Is the working correct. I want to make it sure so that I can implement it using PWM and Timer. I am using SIRC Protocal mentioned here. https://www.sbprojects.com/knowledge/ir/sirc.php
  • mikroC PRO IR.rar
Hi just looked at the protocol and your DSO output, I am considering long width of bursts are high and small widths are low, The problem in your output is It remains high between some of the output bursts....
It is because of the last state of the PWM signal. I will try turning of the CCP1 pin.
Edit: Fixed. I just added a pull down resistor to CCP1 pin.
