abu9022
Member level 3
- Joined
- Jan 2, 2013
- Messages
- 60
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,715
HI friends,
I use the following command
and got the following error
can you check below command is correct way to add +neg_tchk
write_sdf iu_verilog7ns.sdf
Warning-[SDFCOM_NNTC] Need timing check option +neg_tchk
./leon/iu_gates.sdf, 102729
module: SDFF_X1, "instance: TBLEON.TB.P0.LEON0.MCORE0.PROC0.IU0.IU1.iu2.\tr_reg[1][MASK][17] "
SDF Error: Negative HOLD value replaced by 0.
Add +neg_tchk to consider Negative delay value.
write_sdf -version 3.0 +neg_tchk -o junk.sdf
