is there anyone who knows bank swith of 8051?
gogogo
Member level 2
8051 bank switching
is there anyone who knows bank switch of 8051?
you know the largest address area is 64K,
how can i expand the address area,
as i know , through bank switch can,
but how do i do by this method?
is there any stuff introducing it??
thx
farhada
Advanced Member level 2
Nice, France
swith of
If my memory is correct, IAR's C compiler had support for Bank Switching. The method they used was to use 2 or more pins of one of the IO ports to handle the physical addressing of the data and they had a special library to controll the access.
You can write your own code to handle the data. There are many different ways of doing it, hopefully someone has already the code for you here.
BR,
/Farhad
bsiswoyo
Member level 5
INDONESIA
iar compiler banked model 8051
thx
The principles is:
Use additional port as chip select for bank.
For example if you will expand 8 chip of 64KB RAM.
16 Address line use P0 and P2 (as default) is connected to 16 bit address line of RAM.
Use 3 bit additional from P1 or P3 (example P1.0, P1.1 and P1.0) and connect to 3-8 decoder. The output of decoder is connected to each Chip Select of RAM.
In main program must be initiated the P1.0, P1.1, P1.2 all to 0's to select the first chip.
If you select the another chip, set P1.0, P1.1, P1.2 as you need.
silvio
Advanced Member level 3
Romania
8051 p1.1 p1.0
thx
A nice explanation:
https://www.maxim-ic.com/appnotes.cfm/appnote_number/549
and software:
ftp://ftp.dalsemi.com/pub/microcontroller/app_note_software/an81_sw.exe
Self-extracting file demonstrating methods for expanding memory beyond 64 KB.
BANKJMP1.asm: Demonstrates common-page memory expansion configuration using I/O.
BANKJMP2.asm: Demonstrates common-page memory expansion configuration using latched addressing.
