is there any tool that could translate verilog into vhdl?
oasis
Junior Member level 1
[No message]
Re: is there any tool that could translate verilog into vhdl
You can use X-HDL 3.2
It is the premier Verilog <=> VHDL bi-directional translator. X-HDL performs translation of even the most complex RTL/gate-level code efficiently and requiring few, if any, "hand tweaks" of the translated code. X-HDL also contains specialized algorithms which are very effective in translating behavioral-level code to functionally equivalent target-language code.
X-HDL is supported on the following platforms:
Sun Sparc: Solaris 8 and 2.6
HP-9000: HPUX-10.2
PC-Windows: Windows 98/NT/ME/2000
PC-Linux: RedHat 7.2 and 6.*
X-HDL uses industry standard FLEXlm licensing and provides both floating and node-locked licenses.
But there are some lilitations in this tool ,
It will not support Verilog 2001 features.
it convert VHDL 1987 to Verilog 1995, fetures.
try visual
it can read VHDL and write output in verilog
Do you know a tool that translate Systemc to VHDL?
gentle_man said:
try visual
i don't think visual elite is a good choice.
one can write vim scripts to do it
Even a shell script can do that as well. :)
We got blocking assignment in Verilog but not found in VHDL
can translater translate that ? Be very doubtful! 8)
