Is there a X-PCI (miniPCI?) interface?
davorin
Advanced Member level 3
Switzerland
X-PCI (miniPCI?)
Someone ever heard of X-PCI interface?
Have a small Vortex86 board with a 64-pin socket wich supposed to be used to attach PCI periphals...
Re: X-PCI (miniPCI?)
PCI-X is an enhanced PCI that has different bus timing and speed (up to 133mhz vs 64/32 ) then standard PCI. If it is a PCI-X bus then you need a pci-x adaptor card instead of a regular pci card.
Nothing to do with PCI-X which is used like in newer Macintosh models...
Found the pin description from www.vortex86.com and a X-PCI to PCI schematic...
Though strange it is missing the IDSEL signal...
