There is also some commercial RTOS but I don't know then very well. You should take a look on previous post on this forum and/or on the microchip forum.
--> How is RTOS installed on the Controller.., it is same like putting a hex file on the controller..??
--> How is the code develped..? Is the code developed directly with a compiler on a PC and then ported on the Controller Running on the RTOS. or The code developed on a PC with some Compiler or program that provides an simulator kinda thing..??
or how this process is done??
hi movie_freak
please try my rtos for pic 16-bit micros available here:
Included is pdf doc file with small rtos tutorial plus working examples. Runs with mpsim in mplab using logic analyser window to see task running order.
