is there a need of switch before relay in the below ckt??
is that switch is really needed?? if needed what is the use??
what type of switch is that??
help me pls...
It's up to you if you want to use the switch or not, there is no problem with the functionality if you don't use it.
The switch adds the option to disconnect the mains power (phase) from the lamp section.
Any mains switch that can handle the lamp current will do.
Switch S1 to S7 are used for control each relay for inuse or not. S8 is for Power control of the whole system. You can use any orinary AC main power toggle switch.
No the are not, S1 to S7 are switches as pico wrote, I thought the question was about the appliance switches in the top of the schematic which re the relay.
