Is the main power frequency important to Induction Cooktops?
calenosa
Newbie level 5
Hi everybody,
I would like buy a 3kW induction cooktop. The one I intend to buy requires a power source at 220V/60Hz. However, in my country, the main power is 220V/50Hz. Does this difference in frequency cause any incompatible problems? Can I use the induction cooktop in my country?
Thanks.
Hello
It shouldn't matter *that* much, except for the input filters; the resonant LC tank is at its switching frequency. Of course, it depends on its internals for which, I cannot say anything.
But, for some comforting thoughts, if you have access to some testing facility and if it has the possibility of adjusting the power output, you might be able to connect it to an autotransformer with 150V, for example, and gradually start its power from zero. If it won't work, gradually increase the input voltage and repeat the process, while doing measurements.
Vlad
Hello
Vlad
Hi, thanks for the answer.
Unfortunately I don't have any test equipments, that's why I have to ask you guys about the potential problems this incompatibility may cause.
Shouldn't really make a difference. To maintain a decent power factor over such a wide range (0-3kW), the device probably has some kind of active PFC boost circuit built in, which means could feed it pretty much anything. Input magnetics, EMI filter, might be the only thing to look at. They derate with lower frequency.
Some ckts which respond to 50 Hz supply don't respond to your 60Hz do go through the device manual before using
It's impossible to know for sure without closely looking at the design, but I would assume it doesn't matter. Different line frequencies generally only matter in cases where there's a line transformer, or if the frequency of the AC line is used for some control of the system (like for phase triggering in triac rectifiers). It also may matter slightly if a simple bridge rectifier. But for modern, high power appliances, there is likely a PFC preregulator first, and that should not have a problem with 50Hz.
