isaacnewton
Full Member level 2
- Joined
- May 13, 2004
- Messages
- 143
- Helped
- 12
- Reputation
- 24
- Reaction score
- 8
- Trophy points
- 1,298
- Location
- Earth Village
- Activity points
- 1,134
LAMBDA ?
I have a question about Channel-length modulation parameter - lambda. I copied the following from:
www.mosis.org/cgi-bin/cgiwrap/umosis/swp/params/tsmc-025/t4cs_mm_non_epi-params.txt
Is the 'lambda' there channel-length modulation parameter? Thank you.
Copied from mosis.com
End of copy
COMMENTS: Poly bias varies with design technology. To account for mask
bias use the appropriate value for the parameters XL and XW
in your SPICE model card.
Design Technology XL (um) XW (um)
SCN5M_DEEP (lambda=0.12) 0.00 -0.04
thick oxide, NMOS -0.01 -0.04
thick oxide, PMOS -0.06
SCN6M_SUBM (lambda=0.15) -0.06 0.00
thick oxide, NMOS -0.10 0.00
thick oxide, PMOS -0.15
