Is the clearance enough?
tony_lth
Advanced Member level 5
Beijing
ALL,
I designed a 8W GSM module, and the attached JPG is the 8W GSM TX trace.
The trace width is 2.7mm, and the around vias are ground.
The clearance between the GND and the trace is 1mm.
I doubt is it enough of the 1mm clearance?
If the 1mm is too narrow, would it cause any spurs in 500M-800MHz?
Best,
Tony Liu
PS: the DC is 12V.
How should transmission line geometry related to spurs? I presume you'll want to implement 50 ohms impedance. Dielectric strength required for 8W isn't so critical.
There seem to be misplaced ground vias.
the top ground pour being 1 mm away causes excess capacitance. Consequently, you have to narrow the trace width to maintain 50 ohms. Did you calculate the trace width with that in mind, or did you ignore the capacitive effect???
I used the LDMOS, i.e. AFT09MS015N, and copied its recommended 870M circuits. So the impedance should be OK.
Now the PA worked fine.
Only with a spur -38dBm@700MHz, but standard is -36dBm.
So it can pass TA.
I only doubt if the spur is caused by PA itself?
Best,
Tony Liu
  • AFT09MS015N-783349.pdf
I'm wioth FMV & bif44 on this. I doubt the spur is being caused directly by the gap-to-ground but notice that there is vias in that gap. That gap-to-ground has to be doing odd things to your impedance. While waiting for a simulation to finish, I ran TXLine... I don't see this tracewidth and gap calculating to be 50ohms. The two tight bends so close together could also do strange things to impedance, but that could be a design trade-off.
Non-harmonic spurs are a PLL problem and can't be generated by the PA.
Here is the comparison of the Mitsubishi PA and NXP PA.
The main signal is at 887M GSM with 39dBm, the insertion loss is 8dB for freq <=885M.
Mitsubishi PA causes some spurs at 770M, but the spurs level are below -55dBm.
NXP PA causes spurs at the same freq, but the levels are about -47dBm.
Both with the same input.
The standard are below -36dBm, if added 8dB, i.e. -44dBm.
So I think that is the difference of the PAs, different PA cause different spur level.
Spurs can be sourced by different reasons such as power supply originated,grounding and layout originated,circuit itself,decoupling,external unwanted coupling,nonlinearity,measurement equipments etc.
It's really difficult to say something consistent without examining the circuit.
