is post layout simulation obligatory?
memsgg
Member level 1
cambridge, UK
I design an ic using an opamp cell from CDK, but the CDK can not do the post layout simulation including the opamp cell, my quetion is:
1. I don't want to design the opamp by myself, is there any problems for using the opamp cell from CDK?
2. what is the postlayout mainly for? I think it is for paracitics capacitor and resistor, is it right?
3. the working frequency is less than 10kHz, must I do the post layout simulation before tapeout?
Thanks in advance
Yong
Yes, post layout is mainly for parasitic capacitors and resistors.
It's not a must , however it is risky to tapeout without post layout simulation, however u can add parasitic capacitors and resistors at the sensitive nodes in ur circuit to check the affect of layout parasitics on ur design but this also doesn't guarantee that u have taken all the layout effects in ur consideration.
    memsgg
I don't know how to do now, the Design kit uses dracula to erc and lvs, but doesn't support the post layout simulation if I use their opamp cells. is it strange?
And I think 10kHz is low, and the parasitic capacitor should be ok, is it right?
Can anyone help me?
Thanks a lot
hi!
i tried post layout simulation but only after i designed the op amp itself. i instanced my own design after parasitic rc extraction. haven't tried simulating the available op amp included in the kit.
try designing one?
- al
    memsgg
But I think the frequency is very low, 10KHz, so it is unnecessary to do the postlayout simulation, is it right?
