syamin0712
I want a verify does the LT1360 is a low noise amplifier because it was not mentioned in the data sheet?
I'm confuse when comparing it with others device. For instance, in data sheet AD8055 it was mentioned that the ic is low noise ( 6 nV/√Hz ) but at frequency 100kHz while LT1360 has 9nV/√Hz at 10kHz frequency.
I know both of it is a high speed op-amp.
View attachment Lt1360.pdfView attachment AD8055_AD8056.pdf
Could anybody explain?
