mcmsat13
Member level 5
Please, my honourable friends in EDA, I need your help! This electronics of a thing sometimes push a guy from side to side an d man will be set dangling like a small teddy bear hanged on a car front roof!
I have been using IGBT singles in my inverters. Now I have access to disassembled Mitsubishi Powerrex IGBT modules, 200A/1200v, 300A/1200V and 400A/1200V.
I use Push-Pull Center-Tap configuration for conversion. As I gave the modules a close look and I begin to doubt it's application to my existing configuration. They seem to be made only for half bridge
Below, I attached the picture of the IGBT and its symbol, the diagram drawn in Proteus is the way my existing setup is. Please I beg you to find out if there is a way I can use the IGBT modules in that con figuration.
Then if it is nit possible to use it there, then can you suggest for me the possible modifications I will make so I can make use of the modules.
Thanks.
Thanks.
