Is it possible to short nand gate out puts...?
honey 77
Hi All,
I dont have any idea about gate operations, now iam designg hardware part here iam using demultiplexer(74ls138) for chip selection but i want only one out put, here i given 2 adress inputs and one enable input but i need only One OutPut, can I make Short All outputs to single output?
ud23
Advanced Member level 3
demultiplexer is used for getting n output from single input if i am getting you right you need to use multiplexer rather then demultiplexer where in mux you have two different input and single output
correct if i am getting you wrong.
honey 77
yeah , i know what iam thinking that one wrong, but i hoped it maypossible.
ud23
why you want use demultiplexer? you can replace that with just multiplexer and you still want use demultiplexer then use other OR gate after your demux output to get single output and in that case you get output high when any of one go high.but its complicated you can use simple multiplexer instead demultiplexer.and if u still use OR gate then when both inputs high then also your output go high which is not good i guess.
