Is it possible to program PIC 16C662 in C
bigdog1
Is is possible to program PIC 16C662 in C uing PIC Hitec C compiler.
I am new tp programmingin C. Could someone direct me to some good online tutorials for PIC in C.
Thanks,
It is possible because c is compiled to machine code and saved in a hex file.
Problem with the Pic16C type micros is they are one time programmable devices, meant for code that is tried, tested and stable.
For development, it is better to use a PIC16F type device such as a PIC16F74.
These have flash memory and can be programmed and re-programmed many times during the 'try it and see if it works' code development stage.
Just try the mikro C and it free for 2k memory size. Please use the PIC16Fxxx and this flash base and can be reprogram.
