Is it possible to make larger resistors from MOSFETS?
anhnha
Full Member level 6
Full Member level 6
Hi.
I need to create larger resistors from MOSFET (about 1 to 3 MΩ) for my bandgap reference.
I can't use normal resistors because their sizes are too big.
Could you tell me how to do that?
I use TSMC018.
You can, provided that you aren't especially fussy about
the value or linearity. Linearity requires that Vds be kept
low (so you might want many segments, such that Vds<
Vgs) and body effect will then come into play, impacting
segment-linearity.
But you see this kind of thing done a lot especially in a
CMOS op amp compensation network, the zero resistor
is often a MOSFET.
Reactions: anhnha
    anhnha
Thanks.
I intend to use the resistors for this bandgap.
With this bandgap, I can use small values for R1, R2, R3 however the power consumption will be very large.
The resistors from MOS using for bandgap doesn't seem a good idea because non-linearity but I think I have no option.
This resistors require high linearity and positive temperature dependence factor so it's bad idea to replace them with mosfets.
Reactions: anhnha
    anhnha
Thanks.
I am somewhat aware about that but is there a solution for this?
I need to design a bandgap with low power consumption, small area.
However, two constrains are conflict.
Larger resistors => Large area (bad) => small power consumption (good)
Small resistor => Small area (good) => large power consumption (bad)
If you have a solution, please let me know.
Hello anhnha. I check one idea by adds some pmosfets in series with resistors. Below my schematic (in ams0.35um) with dimensions and dc OPs.
I found some disadvantages:
1. The reference voltage is more sensitive to temperature than in classic implementation.
2. Vref has strong dependence from R0. You will need to check worst case simulations
3. Probably You supply range decrease (fets in that configuration needs higher supply, but You have to check in your pdk)
4. I spend on it only half hour so I don't guarantee that this is final solution ;-)
//edit: Maybe it will be good solution to add pfet current sources biased from better node than ground or to use simple amplifier stage to control them Vgs.
Reactions: anhnha
    anhnha
Thank you, Dominik Przyborowski.
Your work looks good! :-D
How about your line regulation?
I will try it now.
Thanks erikl. One of my friend looking for high value resistor with good linearity for wide voltage drop for neuro readout.
@anhnha: unfortunately I didn't check it. Now I haven't time for nothing more than writing thesis ;-)
Reactions: anhnha
    anhnha
If possible, could you explain a bit how the MOSFET resistors work?
(maybe a link)
You can get MOS resistors with relatively linear behaviour either by MOSFET operation in the triode region (high Vgs, small Vds, low resistance)or by operation in (a limited part of) the saturation region, where the Ids vs. Vds rise is mainly given by carrier velocity saturation ("Early voltage"), works only at medium Vds voltages, but in a larger Vds range than in the triode region, resulting in relatively high resistance values, which, however, depend strongly on temperature.
See this Ids vs. Vds (= vdd) characteristic: Id_regions.png
For more info about MOS resistors see any (design) book on MOSFETs and search for this keyword, or for the a.m. operation regions.
Reactions: anhnha
    anhnha
