Is it possible to back annotate from Cadstar to Orcad ?
antarveena1982
Member level 3
I have i schematic in Orcad and layout in Cadstar i want to positional rename in the layout file and also back annotate that changes to the schematics , but the back annotation file formed in the Cadstar is not
supported by Orcad.
Kindly help me out
Thanks in advance
regards
Antarveena
renaming in cadstar
AFAIK cant be done.
How do you expect two completely different systems with completely different library structures to work together like that?
Recreate the schematic in Cadstar.
back annotation
I agree with Cyberrat ..It can not be done..
Antarveena!!
at this point ,i want to ask an question..what is need/advantage of doing renaming in layout.
we also do renaming sometimes but in schematics..like in ine sheet it is from 1-100 and in other sheet it is 101-200.
thanks
abhi
advantage of back annotation
For cross systems this is a manual job only.
You need lots of notes, perhaps a spreadsheet to keep a list while your doing it.
Good luck.
Back Annotation
Hi antarveena,
it is possible to back annotate from cadstar to orcad
Following is the process:
1). generate the back annotation .rin file.
2). open it in text editor.
3).now as shown in attached image clear all the data except old ref des and new ref(nothing else shud be there).
4). save the file as was-is-file.txt.
5).now select the schematic in orcad click the back annotate button and import the was-is-file.txt.
hope this will help you.
Regards,
Ricky
Re: Back Annotation
Thanks all
But special thanks to ricky uhelpd me lot hope othe will also understand.
thanks alot
regards
Antarveena
