hi,
i want to use ethernet mode for communication between pc and microcontroller. so is it must to write tcp/ip stack coding for that communication when i use pic18f series or separate ethernet controlleror ENC28J60.
Whenever i tried to download the webinars either in presentation format or in pdf or even trying to view the video it is giving that page cannot be found..
I'm asking programming mode.
It said ENC28J60 has inbuilt interface coding. so just a SPI data transmission coding for micro controller is enough. is to correct?
And why should i use download the TCP/IP stack via
Microchip's TCP/IP stack provides a library which enables one to create TCP and UDP clients and servers, send/receive packets, etc. i.e. it saves one the complexity of writing code to drive the ENC28J60 hardware. The stack also comes with lots of sample code for PIC18, PIC24, dsPIC and PIC32 showing how to use the stack.
