IRFZ44N. MOSFET .drive from AT90PWM3
Dinuwilson
Full Member level 1
can i drive mosfet drictly from AT90pwm3 PWM output..
input voltage(supply voltage) - 12V
my recomended ouput is 10V
frequency 20khz..
gate resistence is 10ohm
gate voltage(from at90pwm3 )--5V
i am driving mosfet directly from controller with out any isolation....is it possible to get 10v output by using 5v gate voltage..
i am alredy checked with 97% duty cycle in 20khz frequency. my output voltage is in 2.3v... if i decrease duty cycle voltage is decreasing..
Did you activate the AT90 internal output pull-up resistor? If so, its resistance may even be too large to load the ≈1nF gate input capacitance of the IRFZ44 in due time. Try and add an external pull-up resistor (suggest: 470Ω) between +5V and the AT90 output pin.
thank's for your replay..i tried that circuit which you are specified. but i cant get maximum output in my mosfet. i got one equation which specifies mosfet output voltage equal to gate voltage-threshold voltage. i use one 5v to 12 v shifter and got output
