IRFP250 mosfet maximum voltage on push-pull config
kicha
irfp250 power supply
Hi any one help me irfp250 push pull configuration what is maximum dc volt use how to calculate?(Vdss-200V - Rds_on 0.085- Id 33A)
Regards
kicha
stefano.delfiore
Member level 2
Italy
irfp250n psu
Regards
kicha
in a push-pull configuration the voltage across the mosfet in off state is double the power supply. Moreover there are spikes due to the leakage inductance of transformer.
The power supply in your case must be less than Vdss/2 = 100V, how much less depend on your trasnformer, a 30% less could be a reasonable margin of safety.
Don't forget to do a good layout of the circuit and wind the two primary of the transformer in bifilar.
stefano
