i have designed a half-brge using ir2110 and Tlp250 ( input for ir2110) VDD for both =12V ;
Ir2110 Lo pin is working correctly going from 0 to 12V but HO pin is going from 0 to 7V , cusing the o/p to vary from 0 to 7V. And when i connect load from O/p of brg to ground , voltage at o/p drops to 0.8V . However, when I connect the load from o/p to +12V than it works, . What i think that the lower mosfet is switching correctly but the High side MOSFET is not operating correctly. Any Advices.
Biasing
i have did same biasing of MOS as shown in IR2110 APP Note. and added a 1k res b/w gate and source of each mos.
