Benn Ng
Newbie level 6
hi guys,
reading up this forum i still encounter this problem, please advise.
circuit as attached.
the signal high and low logic is being fed out an output from the optocoupler with frequency 32khz and vpeak of 6.2V. i want to test the output of the HO and LO of ir2110 to see what the voltage but i could not see any signal being output? being its is fed into the mosfet gate.
do i need to put a full bridge circuit to test the gate signal that is produce? or i can just test by using a scope directly pluck at pin7 and pin of ir2110 to see the waveform. no signal is being detected currently. please advise thanks you
regards
regards
