IR transmitter using microcontroller
anakramalan
Newbie level 1
Newbie level 1
from microcontroller to transmitter
I am currently doing a project that is using IR.And I am at the transmitter part.
From what I read,there's a lot of protocol that can be used out there but we can also make our own protocol.So i decided to make my own.
One question that I would like to ask is how do you make the modulated carrier frequency to 38kHz using the microcontroller?
I am currently using atmega48.
u can generate 38kHz freq either by using delay routines or by using timer interrupts.
if u are using RC5 protocol, then u need to embed the data bits into this 38kHz freq
generate 38 khz 8051
HI
There is a fine application note at NXP site for using a microcontroller as IR transmitter & receiver For the LPC9xxx microcontroller (8051 best)
The code written in C language and it is a bit easy to convert to any other micro
All the best
Bobi
The microcontroller specialist
Re: generate 38 khz 8051
HI
All the best
Bobi
kindly provide the link...
LaTeX Commands Quick-Menu:
