IR-reducing problem in Magma software
lnc
Newbie level 6
IR-drop problem
HI all member !
I am using Magma design software . My company is doing a project about analog-code . I have problem with IR . As require as customer , We must reduce IR at 50mV . I have tried hardly by I have only reduce IR at 65mV . How can I reduce IR at <50mV .
Please help me !
( I am sorry about my English skill , it is not good )
IR-drop problem
please specify your problem.
in general ways, widen your power rail and strip, adding cap filler, modify your power supply pad position... all can help you on IR drop reduction, however, at the expense of more power consumption on power network.
beside, ask your customer a more reasonable power consumption value. maybe you just using too pessimetic ones.
Re: IR-drop problem
IR drop values are quite related to the process technology. For 3.3V 0.25 um process 100 mv is not a problem. However we definately need lower values for 0.13um process somewhere around 60mv(this last no is my guess).
Re: IR-drop problem
You can make width of power ring bigger.
IR-drop problem
flip chip package may be the solution for big chip.
Re: IR-drop problem
Static IR-drop:
First, find out the hot spot.
Then try to improve the power distribution,
- 1) power source: location of power pads, and provided current
- 2) power network: density of power mesh
Dynamic IR-drop:
- Try to add decouping capacitance close to hot spots.
