lhlblue
Member level 3
i use an IR preamplifier IC(including I-V converter, preamplifier, AGC amplifier, bandpass filter, demodulator, shaper. etc) and a PIN diode to build an IR receiver. but when i power up, there are some spurious pulses at the OUT pin (NO IR signal present), and the width of the spurious pulse is about 200us~300us, very strange.
does anyone meet this problem before?
i doubt the spurious pulses come from power noise, so i add a 100ohm resistor and a 1uF capacitor to filter the powe noise, but it doesnot work. or it comes from the ground noise, but how to deal with the ground noise?
in the IR preamplifier datasheet, it said that, the connection between diode and INPUT pin should be as short as possible and carefully be shielded. what is the meaning of 'carefully be shielded'? how to shield it well for me?
the width of the spurious pulse is about 200us~300us, so maybe it obeys some rule, or it may come from some fixed reason. but i don't know what it is.
so, can anyone give me some related suggestions? thanks.
