lhlbluesky
Banned
i'm designing an IR receiver recently, as my former post shows, it includes a bandpass filter with center frequency f0=20khz, 26khz and 38khz. in front end, i use a reverse-biasd photodiode series with a resistor to be the I-V converter,and a HPF (a capacitor with a resistor)follows, then entering the input of VGA (VGA: vth=0). now, my question is, when the photo current is very small, 1nA or smaller, the signal in VGA input is very small also(and not half-negative, half-positive, may be all positive. while in large photo current case, the input of VGA is half-negative, half-positive, that is, during one period, at one half period, input of VGA is smaller than zero, and at another half period, input of VGA is larger than zero), and so, not amplified rightly by VGA, so the final output is wrong also. besides, the input photo current may include 3uA 120hz noise and 1uA 50Khz noise, in such case, the small effective photo current (1nA or smaller) can not be recongnized rightly by VGA even more. therefore, i want to know, how to receive the very small photo current correctly when existing noise (above mentioned)?
thanks all.
thanks all.
