IR emitter and Detector
snishanth512
Full Member level 3
India
How to characterize IR emitter and Detector?
I have QEE113 as emitter and QSE113 as detector.
It was mentioned as ESD sensitive devices.
Is it must to wear wrist band ?
I have all instruments such as CRO, DSO, Signal generator, etc.
But I don't know how to characterize the leds?
IR detector is a photo diode. You can measure the ambient light using IR detector [QSE113]. you can connect the multimeter to the IR detector & in reverse bias condition the resistance will change corresponds to the ambient light...
You can make a simple square wave generator & connect it to the IR emitter in forward bias. You can see the IR wave using your mobile phone camera.
Udhay
QSE113 is photo-transistor.
Characterization:
I mean
How to check whether IR emitter and detector works according to the datasheet ?
for example how calculate
Power radiated
power received
intensity at given point
approximate photons ejected from the ir emitter
approximate photons received to the IR detector
