irfansyah
- Joined
- Dec 29, 2004
- Messages
- 106
- Helped
- 9
- Reputation
- 18
- Reaction score
- 1
- Trophy points
- 1,298
- Location
- New South Wales
- Activity points
- 1,128
inverter ramp input
hi, i wonder if anyone can help me with this "inverter delay measurement" problem i have.
Normally, textbooks define inverter propagation delay to be = RCln(2), which is the time interval between 50% change in input to 50% output change (CMIIW). Apparently, this formula is only good for very small input rise/fall time, and fails to predict inverter delay if slow ramp input is used.
One thing odd that happens when i measure propagation delay according to the above definition is that i can actually get a NEGATIVE value of delay (50% output happens before 50% input), particularly when input is slow and output is very lightly loaded. So i simply changed the way i measure delay to be the time interval from output's initial value to 50% change of itself. BUT, the values i get becomes way off the estimated delay according to the above formula when i use it with fast rising/falling inputs.
Hence, here are my questions:
1. Am I doing the right thing when i measured propagation delay to be time interval between 50% change of input to 50% change of output?
2. Are there any simple yet widely acceptable formula to estimate inverter delay with slow ramp input?
Many thanks.
Many thanks.
