I am currently making my final project for my degree in electronic engineering and i will impliment in my device a pure sine inverter. My question is this, why does the circuit i am attaching from the EG8010 Needs 400Vdc and not 320Vdc for the spwm? 220v rectified gives us 320vdc, i dont get it. I want to put to this circuit 320vdc , do you think it will work?
this is the datasheet, in every circuit it needs 5,12 and 400v. i get the 5 and 12 but why 400 and not 320?
It depends on what is the AC output voltage you need. If it is 220 VAC, then using 400 V gives you a bit of margin on the DC link for any unwanted dips or fluctuations.
But if my power supply is a regulated 320VDC would it work? I mean the output of my push pull step up converter is regulated and independent from the load i will attach, in this case can i use 320VDC?
It could work if you can accept slightly lower max AC output voltage. This again will depend on how much power you draw. The FET's losses increase with current and should be taken into account.
@ Neonwarrior, the PWM is most often filtered before being applied to loads - hence the fundamental only comes out of the filtering, 230Vac, sine, 325Vpk.
If truly designed for 325V peak then an appliance will not survive 400V. If it has some degree of safety factor designed into it then it's chancey, depending.
Your homebrew inverter ought to be voltage regulated, possibly by a combination of shortening all pulses, and proper filtering.
