deepuvasant
Newbie level 1
Inverted F antenna clearance from Board edge.
I would like to know what should be the minimum board edge to inverted F antenna clearance, currently having only 11.3 mils. Can I proceed with this or need to increase the clearance??
Also, based on my customer's mechanical details there are two mounting holes in the antenna copper clearance area, I just removed the plating from these holes. Is that enough??, or if they mount a mechanical screw in this area in future what will be the effects??
Kindly help me.
Thanks,
Deepuvasant
Kindly help me.
Thanks,
Deepuvasant
