highwaykind
Newbie level 3
We've got an Inventum WS86 scale that's incredibly useless.
The display automatically turns off after some seconds so if you're in the middle of weighing eggs/flour etc you're screwed.
I dismantled the thing, and that's as far as my electronics knowledge goes.
I'd like to know what piece on the board I need to destroy / disconnect in order to completely disable the automatic time off function ( the scale has a power button that turns it off too) while keeping the rest working.
If I accidentally brick it, no problem (at least I'm learning something).
I can take pictures of the board, the numbers are C1991203 and C1991101 (just in case there's a database somewhere for this stuff).
I could also try to copy it in a drawing (but I might need a tutorial for this, it seems complicated and I don't really know where to start?) or do whatever else is needed to figure this out. Things do seem to be labeled (R12, C12, Q3, U3 etc.. I'm guessing everythign R is resistor? Not sur about the rest, there also is a jumper. Board has 2 sides, and on the other side I can figure out sensor + an -, ground a+ and - Cal1 and 4 black cylinder thingies L.S 105 Celcius)
Thanks in advance!
Thanks in advance!
