Intrusion Detection in OPNET.
Bomaigee
Newbie level 1
China
Hi, I am doing a project in Simulating Intrusion Detection in OPNET.I am new to OPNET and thus i need help here..If someone who has done a simulation like this please upload the simulated IDS in OPNET so i can just run it in OPNET.
Furthermore any advice or help in any way would be much appreciated.
Thanks!
BGee
Thanks!
BGee
hii
i have to implement the same thing...wil u have cmpleted that then guide me i am new user of opnet and have to implement intrusion detection system.help me if u can
Re: Intrusion Detection in OPNET. A
Hello, I am working on Intrusion Deterrence System. I need a good Intrusion Detection System to use. Any success with your work?
Hello all.
I've been away for long.
now that I'm here, I'll be writing.
now to your question;
OPNETs use session keys that work on first captured basis.
the only way you can simulate that is using hyper threads and a series of if else statements in any programming language.
however, if you're into scripting, Python has network library, I'm not sure if its free or not. But its worth a try.
you need to access the network at session layer when user logs in and a session key is computed, check for duplicates of id, password or session key.
the other method is checking for decaying time stamps or hop counts. which I'll write about a bit later.
hope this helps
Cheerio
-Harsha Jois
