Intialization of SDRAM DDR2 memory in Xilinx tools
Taki_comp
Member level 1
I would like to know how can initialize the content of DDR2 memory using xilinx tools ? my purpose is to load to static images to the memory before starting its operation, meaning initialzing different memory locations with different pixel values.
ads-ee
Super Moderator
Staff member
USA
You can't initialize a DDR2 memory device unless you mean writing to it after the Xilinx FPGA is configured, after the DDR2 controller has finished calibration, and there is supporting code to write the initial data into the DDR2.
Taki_comp
Member level 1
what about flash memory ? I am using digilent Atlys board
ads-ee
Super Moderator
Staff member
USA
You can't initialize external memory devices using Xilinx tools, you have to design logic to write to the device after configuration and after any FPGA controller IP core initialization.
vGoodtimes
The board appears to have a QSPI flash for configuration. IIRC, iMpact did have a way to program arbitrary data -- normally an OS -- as well as the normal .bit file. The tools program the FPGA with a minimal build that has the jtag to config-pins interface. You would still need to read the image from flash and write to RAM.
--edit: it looks like the board manufacturer's programming tool also allows you to write data files to the flash in addition to the normal programming file.
Taki_comp
Member level 1
why would I still need read images from the flash and write to RAM ?
